Turbo kit for G40
Hi there,
I have a turbo conversion for sale that comprises of the following.
Genuine KKK K03 turbo with forge actuator
Rothe manifold
Downpipe with heat wrap
Forge dump valve
ECU with PPP turbo chip and 250kpa map sensor
315cc injectors
Front mount intercooler and suitable silicone hose. As you can see from the pictures below the intercooler is a great fit at the front of a mk3 polo. Silicone hose included was over £100 alone.
Newman PSD turbo cam
Nearly new set of tappets for the cam
Throttle body with boost switch installed and welded up elbow.
Tapped sump for the oil drain
Oil and coolant lines
Air filter
Alternator
Engine mounts
Pulleys
Suitable spark plugs
Bumper bar with hole cut in to allow cooling for the intercooler.
Front bumper with holes cut in to allow cooling for the above bumper bar.
Basically everything needed to convert straight to turbo. I have run this setup for a while and it has made good power and made for a quick car. This setup is located in Sheffield. £950.
9557fe6cb15a7e1c5496193ba11a0901_zpsf896
5e39fef95dc7fad9c5ca4ae7613d8420_zpsba1a
18a1772ee496a1e08f11fd7f38e675f3_zps6bea
d7cffa4801ddf8e1d62d25808989e6c1_zpsd581
7966928158e374391c37dc2d1779796a_zps1467
A96EC6B9-2B5A-40F1-A7E1-098AE7520E7B_zps
7A5B8C50-AC9E-4783-9E43-9F21B6E72F67_zps
E01F89A6-5B62-4865-92DB-F819AAC7C2C7_zps
  • Views 1k
