Montreal II Alloys?
Just a quick question, as I know it's been done loads of times - will 16 " Montreal II alloys (as fitted to the Mk4 Golf GTI and Polo 9n2 GT) need spacers if I fit them to my 9n1? Also is the rolling radius affected?
Many thanks.
Edited by PoloPowerr
  • Views 1.2k
Popular Days
  • Shouldn't need any spacers. These are easy to get hold of so bolt them up first and see if you need them As long as the PCs is 5x100 then they will fit. Some polo came from the factory with 16" whe
Some polo came from the factory with 16" wheels, so as long as you use the same sized tyres then nothing would be effected.
Not sure on the tyre size, but it's in the handbook or sticker in the petrol flap (for tyre pressures)
