VW Polo 6n 1.4 CL
VW Polo 6n 1.4 CL.
I've owned the car since November 2012 and has done about 2500 miles since then.
104,241 miles.
MOT until July 2016
Lowered on coilovers,
Mini Imola wheels, there is a slight curb mark on the nearside rear. (See pictures) Running 20mm hub centric on the rear and 25mm on the front.
The car was resprayed in 2013 In Mercedes White. There are a few blemishes in the paint work. (See pictures)
Had new discs, pads, lower arms, tyres in September 2013. Coilovers also fitted at this time.
6n2 rear lights, clear side repeaters, and indicators. Also has a cut out on the lower valence for when I put a twin pipe exhaust on but didn't like the sound so just put a stock exhaust back on.
The car was serviced before it's MOT in July, new sparks plugs, oil filter, oil etc. New handbrake cables and starter motor also fitted.
It has a push start button, so turn the key, push the button. Everything inside works. 6n2 front and rear seats.
There are EDGE component speakers fitted in the doors. I will leave the sub/speaker wiring (Front speakers were running off the amp) in the car so all you'll have to do is pop your own amp/sub in.
Headunit not included. If I can get hold of another headunit to put in there I will do so.
It is a very smart little car, a good runner has never let me down, great fun to drive, is cheap to insure. Certainly turns lots of heads when driving!
Will also include the twin pipe that i previously had fitted.
post-114929-0-25369700-1442513913_thumb.
post-114929-0-41354900-1442513915_thumb.
post-114929-0-94979900-1442513916_thumb.
post-114929-0-43334600-1442513918_thumb.
post-114929-0-46227400-1442513921_thumb.
post-114929-0-49249900-1442513924_thumb.
post-114929-0-45440800-1442513926_thumb.
post-114929-0-97578700-1442513928_thumb.
post-114929-0-57574600-1442513930_thumb.
post-114929-0-24809900-1442513932_thumb.
post-114929-0-08436600-1442513934_thumb.
post-114929-0-48497400-1442513936_thumb.
post-114929-0-16254400-1442513938_thumb.
post-114929-0-24042800-1442513940_thumb.
post-114929-0-02184800-1442513942_thumb.
Edited by Savagesam
  • Views 498
