MK2F breaking, ATS classic, Twin 40 manifold, Powerflow exhaust
Red power coated to a high standard
ATS Classic 6J with matching tyres - £200
5 speed Anti roll bar - SOLD
Rear beam with gladerseite bushes and rear brake drums with new hoses - £150
Engine/gearbox mount - £15 each
Alloy cam cover - SOLD
(MH 1.3 rebuilt 1500miles ago( red sump with magnetic plug, red water pipe, standard cam cover, 272 Newman cam, head rebuilt, double springs) - Have a print out for 90bhp) SOLD
H&H ignition dizzy( recommended by bogg brother no need for vac/adv, Carb wiring harness and ignition module, Flamethrower coil (with red bracket) -SOLD
Magnecor ht leads and custom king lead - SOLD
Brake stone guard - mint condition -SOLD
Brembo brake disc - £20
Brake caliber with fresh pads and new hoses 1000 miles ago - £15
5 speed re-conditioned gear shifter with new bushes - SOLD
5 speed drive shafts - £30
Gladerseite ARB blocks - SOLD
Bottom arms with gladerseite bushes - SOLD
Front steel strut brace - SOLD
Rear alloy strut brace - SOLD
Ashley 4 branch - SOLD
Powerflow straight through to back box - £200
OMP steering wheel with boss - SOLD
Scuttle tray - SOLD
Edited by kanokid
  • Replies 30
  • Views 3k
I know these are small parts but do you have the 4 clips from the lower edge of the front opening. Two are broken in my photo.
post-15736-0-97263600-1443795634_thumb.j
Once the car is being broken they will be available
you have any pictures of engine mate?
thanks!
If I may ask how come you breaking ? looks good..
Arb blocks for me if you can post ?
Edited by 1vw2many
I am keeping the carbs off the car so wont be a runner, I can post ARB blocks
If you can pm about arb blocks please..
Any pics of the steering wheel?
Morning, I need the passenger side window rubber assembly of poss? Text me... 07545955882
Rich
You have a 5 speed box? If so get in touch 07446 981508!
Mitch
Where are you?
Croydon
Any pictures of the exhaust itself or the exhaust fitted to the car so the tip can be seen?
When was the head rebuilt/who by?, what was done? And how much on its own or with the cam?
engine has just sold,
tip is hidden, built by powerflow, inbox me your number and I will send you some pictures.
what does the exhaust look like and breaks condition wise?
60723383-3309-4EA9-BB82-B12DBCCC7507_1.j
both have done 1500 miles
Did you have a look for the clips I asked for earlier in this thread please?
See photo above.
Edited by c.w.pritchard
See photo above.
I will check this evening, i believe so
Good to meet your dad yesterday. If I'd known you were going to MK, I'd have met you there!
You still got the gearbox mount?
What steering wheel has it got
still have all gearbox mounts plus rear poly bushed mount for £50, steering wheel has gone
If you still have the 5 speed ARB would you take £40 including the postage? Thanks
GT bottom end with oil filter, water pump and red powder coated water pipe, was told it had done 60k, £60
Red engine mounts £40
Alloy rocker cover SOLD
Mirrors (pair) SOLD
Mirrors with adjusters (pair) £20
Slim starter £30
8v head bolts £10
Top mounts with castle nuts £15
Wheel bearings £30 pair
Thermostat blank £5
NOS door handle insert £10
Vernier pulley SOLD
Exhaust hanger, drive shaft guard and lower brace (red) £15
Thermostat housings (with or without expansion bottle pipe) £10 each
Rear breadvan lights x 2 £20 per set
Front lights x 2 £20 per set
Indicators £5
5 speed leather gear knob £15
Steering arms £15
Wolfsburg bits SOLD
Oil filter £5
Interior mirror £5
Edited by kanokid
If youve still got the headlights, i'll take them. And what wolfsburg bits you got? Cheers
