RIP Vio's Polo :(
Your money at end of the day. If you got a budget set for it then do it. Will keep you busy for a long time lol.
  • Replies 138
  • Views 7.6k
  • google street view of vios back yard lol
  • to be fair, it was your fault for not getting out the way
  • any pics of the crashed nissan you plan to repair ? cant be much if a garage can do it for £200 maybe its your destiny...vio's crash repair center
I don't have a lot of bodywork skills. But if I did I wouldn't dream of taking on a job of saving a rear ended car, let alone a rear ended mk2f Polo. A small bash on a curb bends them, so who knows how much damaged that rear end impact did aside from what you can see. Have you checked the roof skin since the accident? That can be a good indicator to see if the shell itself has started to buckle.
Then you have the issue of finding rust, once you start digging it's amazing how much you find and how long it takes to fix. Not just the grinding back and welding process but how much you need to take of the car to fix it all properly. Ideally you'd need to strip it down to a bare shell and go from there.
The thing is you could do that to any Polo to restore it properly, so why not make your life easier and start with a straight shell? You'll be achieving the same thing. I wouldn't worry if it isn't a GT or G40 or about doing conversions. But if you do want to go down the conversion route for more power, don't you think it would be better in a shell that hasn't been bent?
Sure, but it still wouldn't be *my* car :-( there's a *lot* of easier things I could do than this... buying a 2f loon, dropping a VR6 in it, transferring my spinners over and saying job done would probably be easier, but I'm not particularly concerned about the level of difficulty. I have a perfectly good Polo already minus some bent bits of metal, and given the prestige of it being my first car and the most valuable posession I've ever owned, it's nowhere near enough to justify me giving up on it so easily. At the very least it deserves an attempt.
"If you find yourself Google-ing ‘car salvage’ but you haven’t gotten your hands dirty trying to fix whatever problem pushed you over the edge, then you haven’t tried hard enough. Get back in the garage and try again." - Marty of MightyCarMods
I know what you're saying, but still I don't get why you would put more work on yourself than you have to. Why put so much time and effort into a shell which at the end will be the same as a shell which anyone can go out and buy.
Since you brought up Mighty Car Mods, think of the Gramps and Super Gramps projects. They could have saved the original Gramps shell and just kept going with that. But instead they put that time and effort into a new shell and made Super Gramps even better.
I get what your saying also, obviously these are just opinions and you should do what you feel is right lol but to me a shell is a shell is a shell
Could even do a cheeky and swap yout vin and reg to a white shell [emoji6]
You could spend 2k on parts and tools to do the work and still have a £400 car
I appreciate what a first car means, I'm spending on mine still but i think your optimism is based on a lack of knowlege on what is involved in cutting the back of you are car out and repairing. Its a long job if you have some practical skills
Also your car will likely need an inspection before it can go bak on the road. Is your welding going to be up to the job
Edited by kiran_182
Vio for as long as I have a hole in my arse, your old car wont be going on the roads, cut the ties and love you have for it and just get another car. Listen to what everyone is saying to you. It's unrealistic to even think that will go back on the road safely.
There are plenty of cheap run arounds, especially the polo you're after, do yourself a favor, start to save and then look for another vdub.
Will you sell me the spinners if you break the car please?
Having had a very similar thing happen to my old Mk2, I feel you are seriously underestimating the amount of work here. It not a matter of cutting panels out and welding new ones in. You have ripples down the side. This can only happen if some part of the car has been shortened. You'll need to identify where exactly this has happened and straighten each part that's bent then replace panels etc. A lot of those will be spot welded, which you don't have. Or you could stitch or seam weld I suppose. You can do this right?
I whole heartedly agree with your ambition to learn new skills and so on. But it's very naive to think you'll get it right at the first time of trying. Take it from someone who has tried to do everything them self in the past and cocked it up, costing money and time in the process (I haven't even worked on my loon for 2 years since I cocked the paint job up). From reading your other posts too you really have shied away from doing anything that doesn't involve a self adhesive backing.
I would encourage you to learn from this however, but don't be so blinkered as to think that you will drive the car again. Learn to weld on it and learn the other bodywork skills required to restore a car and then fuck it off and make the next project decent. Being determined to make this car your learning curve and the final perfect just don't tie together. Learn the skills, make mistakes and start again. Otherwise I agree with Dean's hole in the arse comment
Let the guy do what he wants ffs
because we know it'll end in a failed project at huge expense and will probably put him off working on a car in the future.
even getting a rundown 2f for £100 and spending the time and money rust treating, servicing and refreshing parts would be more productive and provide a wider range of skills and experience
We aren't stopping him from doing anything. We aren't just trying to mug him off here. Everyone here is giving their take to prevent vio spending a bucket load of money on something he is most likely going to regret.
Way I see it he is being so optimistic atm because he loves his car so much and also....because he hasn't started fixing the damaged area. I think it might sink in then so I won't say no more
It's not worth spending the time on, I get that you're attached to it, I would be the same but you've got to just let go.
I'm fairly competent with repairing bodywork but I wouldn't touch that, maybe if it was an expensive car, but it's not.
The best bet is to strip everything off it and buy another Polo, as said you will then have a mountain of spares.
I know some people are just offering advice and trying to help, thats fair enough. But say your piece and move on. Some of the forum know-it-alls just love to keep prodding at people.
If he wants to save it then let him try. He might give up and say 'you guys were right' or he might succeed and prove everyone wrong.
Really sorry to hear/see this matey! Hope you are ok?
Yeah I'm good now, only major physical problem was a sprained ligament from when my foot was on the clutch as I got hit, made walking difficult for a few days but that's all sorted now.
I don't get it - I'm a few thousand pounds out of pocket, lost a car, was out of work and lost good amount of income, had to cancel my RAF application... and yet I feel quite cheerful, and keep seeing the bright side to everything. I think I may have suffered some brain damage too :unknw:
I wish I was as optimistic as you vio. I get an oil leak and start contemplating suicide after not being able to stop it for a week lol
Good way to be mate, don't change!
It'll polish out. And what doesn't, so what? Another bumper will cover that. Most of it. Just tie a rope around a tree and attach it to the towing eye, give it some beans away from the tree, it'll pull half of it out.
The stacked look is gonna be big next year.
My luck has changed somewhat :D spoke to solicitors today, apparently I can still make a claim for car+injuries against the motor insurance bureau. That on top of a non-fault claim regarding the Nissan, and I might get enough compensation to buy a mig welder or something :D
Even though my insurance is writing off Neko (the Primera) I plan to buy it back as the damage isn't that bad, local garage and I could probably save it for a few hundred. I seem to lack the ability to 'give up' on cars. One day I'll end up with a category A and the police will have to drag me away from it as I try to beat it back into the rough shape of a car using a rubber mallet.
But while Neko is being fixed, I need another runabout to work with. And I have my eye on something...
I'm all for buying cars back and fixing them if they are a cheap easy fix. But since you're doing this with the Polo and now the Datsun, plus you're going to have to buy another cheap run around which may or may not need work, just be careful of taking on too many projects.
I've seen so many projects fail because someone has 2 or 3 on the go at once and just can't give the time or money to all of them to make decent progress.
The money and time you spend on the Datsun could be money and time you spend on the Polo...
Just the ones I took at the scene, will get some better pics when it;s light
Bonnet, bumper and n/s headlight all need replacing, but I can pick those up at a scrapyard cheap or find someone breaking a car (the first thing I did when I bought the car was join an owners club :tongue: ), already sourced the headlight. Inside everything works as it should, but the radiator's been pushed back slightly and there are a few important-looking metal bits that need straightening out, which is where the garage comes in. It's certainly not as bad as the Polo where I'd have to be cutting panels off and such.
The Polo was my first car and so that project is allowed to defy logic and reason when it comes to repair costs. The Nissan doesn't have much resell value either, but it's a practical car and a nice drive, and given that the damage isn't exactly life-threatening, I think it's worth trying to coax a few more years out of it.
Looks quite clean for a Datsun!
I've always been a bit in between on the primera...1st and second shape were okay and the GT was pretty cool but I always found them a bit plain.
They are supposed to be very reliable which makes you wonder why they are nearly all gone! Think depreciation might have killed it off when people think they would rather spend a couple hundred on a different car than repair one or get a cambelt done or whatever.
Never did see many In white either...do you have a picture before it was damaged?
Edited by wizardmanjm
