VW Polo Coupe S 1989 1.3 GT Engine
Details
99136 miles
1.3L
Hellios Blue
Extra components from stock
Mk2F Polo 1.3 GT mpi engine 75bhp
Pipercross air filter
Stainless steel 4-2-1 exhaust manifold
Stainless steel exhaust system
Sachs clutch
8000rpm rev limit chip
14X6.5 VW steel wheels
Yokohama A539 Tyres +7mm tread all round
H&R Cup kit suspension
Front full polybush kit including anti roll bar
Front lower, rear upper strut brace
Immobiliser
G40 239mm vented front brakes
Parts replaced during my ownership
Engine rebuild at 85000 miles inc;
Crank bearings
Con rod bearings
Piston rings
Head skim
Valves re-cut or replaced
Valve seats re-cut
Valve guides replaced
All engine seals replaced
Freeze plugs replaced
Hydraulic tappets
Manifold studs
Port matched inlet manifold
Cam belt and water pump
Reconditioned starter motor
Reconditioned alternator
Aux belt
Engine mounts
Distributor rotor and cap
HT leads
Spark plugs
Distributor coil
ECU wiring loom replaced wires
Gearbox seals
Other Work Done
Fuel lines replaced with plastic
Front brake rebuild
Rear brake rebuild
Braided brake hoses
Front wheel bearings
Top mounts
Track rod ends
Lower arms
Bad Points
Rust hole at front wiper
A couple of small dents, some scratches and rust in places, superficial rust only, no structural.
Tear in driver’s seat
Lacquer peeled on passenger door from sticker removal
Heater fan faulty (replacement motor included)
Located near Bridlington, East Yorkshire.
The car currently has 1 months mot but will be sold with 12.
Price £1200 ono
I have lots more pictures, message me if you are interested. I also have many pictures of the engine rebuild.
Please message or call with any questions or to arrange a viewing.
Rowan.egginton@hotmail.com
07564157487
post-90693-0-36149100-1452546860_thumb.j
post-90693-0-00525000-1452546915_thumb.j
post-90693-0-39420100-1452546984_thumb.j
post-90693-0-78506200-1452547217_thumb.j
post-90693-0-54454400-1452547610_thumb.j
post-90693-0-94961200-1452547822_thumb.j
post-90693-0-32466100-1452547911_thumb.j
post-90693-0-60325100-1452548045_thumb.j
Edited by Rowan.polo2
  • Views 887
