Golf elbow
Hi all I've just bought an golf elbow induction kit just for the look and sound as I have a 1lt so I'm clearly not looking for power lol. Does any one have any advice on what cone to attach to the end? Or doesn't it matter? Thanks
  • Replies 6
  • Views 870
I attached a gt airbox using the afm as an adaptor when my aav was spi other than that a cone filter will give a better sound
I think id perfur a cone filter just didn't no what cone size to buy do you think the size will make much different in sound
For a small engine the regular run of the mill will do, youll still get a deeper sound
Thanks for the advice mate. Will look into it that then. I guess if the filter let's in more air I will have do a little carb tuning?
Youll probably get away with it as standard. You will find warm weather takes the edge off
Hi all got round to fitting the intake elbow today yaay. one question??. Where does the little clear hose go I'm guessing on one of the nipples on the back but not sure.
there are two clear hoses on the original ufo filter housing and I'm now quite confused. Thanks in advance
