63mm Stainless Steel Exhaust - G40 Turbo
For sale is my 63mm Exhaust – Built by JP Exhaust (who make Radical systems, and PPP ones). I’m going side exit, and didn’t want to chop up a decent exhaust to do that.
No mid-silencer, this will be silly loud on a supercharged car, built for a turbo, passes track noise regulations no problems at well under 98dB.
Doesn’t use stock mountings (because they’re crap) so will need customer mounts welding onto the chassis.
Standard Lambda boss, only less than perfect bit is my welding of the two sections together to eliminate the old clamp.
Down turned pipe at the back, licks a nice flame towards the tarmac
11705823_923172651054114_887730303001448
£250
Pete
  • Views 305
