Prize Polo (Joels Windsor Blue MK2F)
Well thought I may aswell start a build thread although I haven't picked it up yet [emoji16]
Here's my new 92 CL coupe aav 1.3 5 speed with 84k miles on the clock, that I won for a steep £20!!
I would like to make this more a of a performance based project rather and have my bready as a 'stance' car (didn't know how else to put it). I'd like to try and tune the aav and I've been looking into (and going to continue looking at) a possible turbo conversion. Don't know yet how easy or costly this will be. Want something I can really get my teeth into and basically learn more about cars mechanically. any ideas are welcome [emoji3]
  • Replies 15
  • Views 1.9k
  • The polo is finally home!!! had a blow out on the trailer along the m60 but got it sorted fairly easily time to start work [emoji1] [emoji1] [emoji1] Sent from my SM-G920F using Tapatalk
I tuned an AAV, really shifts. Shout me when you want some info
you have a build thread bud?
£20
£20 ????
£20
£20 ????
yes 20 ahaha won it in a raffle I get my 20 back plus 100 aswell ahaha
If you want to go down the turbo route then take a read through this thread.
http://www.clubpolo.co.uk/forum/index.php?showtopic=272628
Speaking from experience on doing it to a G40 lump though it isn't a cheap conversion. Also unless you have ALL of the parts and have been mocking things up along the way then it isn't the kind of thing that will be done over a weekend either.
If you have the time, money and motivation it will be a worth while conversion.
Cheers for the info, I've definitely got the time and motivation and I'm sure I can find the cash so I'll have a look through that thread got a while to decide yet anyway. thanks again [emoji1]
I'll be picking the polo up tomorrow if all goes well, got the first little upgrade aswell
GT cam I assume?
GT cam I assume?
you would be correct
Awesome, seems to be loads of these popping up just now. Just hope they are all genuine.
What's the way to check? is there a code i can look for?
030 AF should be stamped on the cam on one of the sections between the lobes.
Interested to see where this goes
