dash speedo lights flicker polo 6n2
hi i have polo 6n2, speedo warning lights flicker. nothing wrong with the car. more like some loose connection.
i have checked the following:
battery terminals cleaned
fuses checked (all ok) and cleaned on top of battery cover
interior fuse box/fuses checked
checked the speedo with diagnostics and shows no codes
checked battery negitive lead and earth points and wd40 them
checked, and replaced alternator and cleaned all the connecting points including cable
checked speedo cables and pins all nice and tight
checked battery and alternator with multimeter and shows all good voltage (with engine running and engine off)
not sure where else to look for?
any ideas?
diagnosed the whole system with my machine and no fault codes
warning lights only flickering for micro seconds now and again, not staying on.
cheers
  • Views 831
