Is it worth repairing?
Hi all,
I've recently been offered a May 1994 Mk 3 Polo (bread van) for £200 and wondered if it's worth repairing? It failed on the following things on its last MOT:
Reason(s) for failure
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Fuel tank leaking (7.2.3)
offside Front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
offside front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
offside rear Shock absorber has a serious fluid leak (2.7.3)
nearside front Suspension arm has excessive play in a ball joint (2.4.G.2)
Advisory notice item(s)
nearside front Shock absorber has a light misting of oil (2.7.3)
nearside front Brake hose slightly deteriorated (3.6.B.4d)
offside front Brake hose slightly deteriorated (3.6.B.4d)
nearside rear Brake hose has slight corrosion to ferrules (3.6.B.4e)
offside rear Brake hose has slight corrosion to ferrules (3.6.B.4e)
nearside Rear wheel bearing has slight play (2.6.2)
nearside rear tyre starting to crack
The car has only done 64,637 miles, but I am concerned whether getting it repaired would outweigh its value.
Edited by TopCat
  • Views 1.1k
  • Sounds silly but I often say that unless someone gives you the car then it's not worth it unless it something ultra special like a gt.
I think the MOT report says enough really about how rotten it is and it's as if basic maintenance hasn't been applied.
For about 4-500 you could get one a lot tidier than that. It depends what scene tax people put on so you have to look in the right place and be patient. If I saw that MOT though I would walk away and wait for a better one
Sent from my SM-G925F using Tapatalk
could be fixed up if you have experience with such repairs , but a rusty mot fail isnt worth £200 ,   nearer £50 imo if the rest is tidy
A breadvan in poor condition for 200 hmm I disagree with what everyone else is saying, if you could do the work yourself which by the way isn't that difficult I'd go for it. It's up to you and only you can decide whether to take it on
