What do you class as high miles?
Hi everyone, im looking at a 1.2 tdi bluemotion with 100,000 on the clock. is it something to worry about or are the diesels build like a brick sh*t house and go on forever when looked after?
  • Replies 5
  • Views 1.3k
  • kwijibo_coupe
    kwijibo_coupe
    Maintenance is everything in my eyes! Can't speak for the diesels but I've seen petrol engines give up at 50k miles due to being poorly maintained and others of the same type going for 3 times that mi
Depends on how it's been looked after.  They can do big miles but need regular oil changes and make sure the timing belt has been done.  Personally I would not buy one that has had long life servicing either.
I have a Bluemotion TDI. It had 22k and I've took it to 48k without issues, apart from a lambda sensor. I give it some abuse too
Sent from my SM-G925F using Tapatalk
I've got a polo tdi 2001 1.4 that has 180000 odd mile on it and it never skips a beat so I'll bet that mileage is not even the breaking in mileage I did however hear of someone on another forum having 250000 on theirs and still going strong
thanks for the advice everyone, il look into what history it has and go from there. is there anything else i should check apart from the timing belt? dpf?
Maintenance is everything in my eyes! Can't speak for the diesels but I've seen petrol engines give up at 50k miles due to being poorly maintained and others of the same type going for 3 times that mileage with no issues. So I'd really ignore the mileage from a reliability point of view and look more at the service history.
From a value point of view I'd say 10-12k a year is about average. So if it is on the high side but it has been well maintained you may get a bargain.
