ignition timing mk2
PDF page numbers 87 and 100 in this http://tuningforspeed.com/files/Tuning_for_Speed.pdf also make interesting points on ignition versus compression ratio.
Actual page 163 and 188 in original...
  • 2 years later...
  • Replies 28
  • Views 12.2k
Latest map
Gone down to 30 (+5 static) as now on Unleaded 95, not Momentum99 due to Ethanol crusting phase separation.
  • 2 years later...
did you ever get the stock gk map ?
