Seat Leon 1.6 16v
Here I have my seat Leon 1.6 16v petrol, Currently done 119k , I bought the car as a run around while my other one was getting fixed and it has done me well ever since.
Since owning the car I have replaced the top passenger side engine mount and the dogbone mount as these are know to go over time. It has also had a new coil about 2 months ago.
The engine runs very well and is very quiet even when sitting on the motorway.
The body work isn't the best as you would expect from this age of car. It does have a slight dent on the rear door and a scrape on the near side rear door.
The front drivers side fog light is also broken but can be easily replaced at little cost., , It has full service history mostly from seat and all stamped up until Feb 2016.
The bad bits:
The clutch biting point is getting quite high which will need replacing at some point and does give a very slight judder when pulling off on a hill (again down to the clutch).
But apart from that it is a good car and still pulls well. The clutch does not slip at all so is still perfectly driveable. , Drivers door is a bit temperamental when trying to unlock but still works and locks as it should.
No advisories on the last mots,
Have all recipes from work been carried out on the car even though it has been minimal.
Also have two keys,
Car has 7 months mot left,
£700 located in Plymouth, Devon
Will listen to sensible offers
  • Views 397
