Mk2 AFH bike carbs
My car now on ebay!
http://www.ebay.co.uk/itm/291848617348
From the ebay ad
Thanks for taking the time to have a gander at my old polo.
5% of the money from this sale will be going to ABF - The soldiers charity which supports british soldiers and veterans
First things first, this isnt a car you can drive home.
It hasn't had an MOT for a few years.
I have owned it for over 6 years and for 4 of those years it was my absolute pride and joy. I maintained it meticulously, changed parts before they broke, and generally just adored the damn thing...
then I had to grow up and buy a house, so hence i had nowhere to keep it and nowhere dry to work on it.
add that to the fact that the house i bought was a dooer-upper... and you see why two years down the line i've not hardly had a minute to spare to get the car sorted, and lost a bit of interest really.
so there she has been sat patiently round the back of the house just waiting for me to start finishing off, but now the time comes i think its time to pass on the baton.
So details...
originally the car was a 1.3 coupe s
Eventually the engine packed in, so was replaced with a 1.4 AFH engine from a 1998 Polo 6n.
it runs on CBR600 bike carbs
reconditioned gearbox from 1.3MH engine
front brake disks and calipers upgraded to VWII (from golf GTI)
brand new brake lines throughout
brand new braided flexi-hoses
brand new stainless steel exhaust manifold and downpipe
brand new exhaust to rear
new ignition coil
brand new battery
the aluminium engine head has been die-grinder ported and polished
it has been fully rebuilt with all new seals, new head gasket, valves have been hand-lapped.
new valve seals
custom fabricated surface ground mild steel inlet manifold, also ported and polished
cbr600 bike carbs, fully stripped and cleaned, new fuel jets
ARB blocks fitted
rear coilovers fitted
set of nice alloy wheels included
ok so bear in mind, this work was completed 2 years ago, and since then the car has been kept outside my house not being worked on.
I have been careful to start the car and run it for a couple minutes every now and then.
I have taken a look underneath it, and the braided flexi's and the new brake lines look like they were installed yesterday.
The bodywork i would sa is good, but not excellent.
There are no dints or 'dinks' or anything requiring major work,
the worst part is a patch of rust near where the rear exhaust exits the car
other than that there is just an odd bit of rust here and there, and to say it's been neglected for 2 years, i expected a lot worse!!!
PROJECT DETAILS... (work needing to be done)
The car runs, but will run better with the following:
carbs will need stripping and cleaning out (not a massive job, plenty of guides available online)
once fit again carbs may need balancing, i will be including my carb balancer in with the sale
fuel lines to carb probabaly need replacing (about a year ago i started the car and it pissed petrol everywhere, i did a quick replacement just to get it running again)
brake lines feel like they need re-bleeding
exhaust at back will need a couple of rubber 0-rings (couple quid each)
with the brakes bled up, i don't even see why this would fail an MOT as it stands.
still registered as a 1272cc
once its finished you will have a 120+bhp classic car that weighs less than a ton.
have fun!!!
Edited by nige8021
Details added from eBay advert
  • Views 447
