1.6 AEE Engine + Gearbox + ECU / Loom
Selling 1.6 AEE engine with matching gearbox, mounts, ECU, engine bay loom, Immobliser box, key chip, fuel pump etc, basically everything that you need to run except the exhaust manifold. Everything attached to the engine block comes with it such a throttle body, starter motor (may need replacing), alternator etc. It is currently fitted to the car and will be off in next few days. This will be for collection only. I do have engine crane so loading it on to your car is no issue. Engine gearbox, gear change all nice and runs as it should. £100 for the lot. Collection from Bedford. Thanks for looking.
  • Views 287
