6n2 2000 1L spigot length
So i began a quest of getting spacers and found out that some may not fit as the spigot of the wheel hub (the lip) may be too long, after searching the internet in order to avoid going out and measuring my own ones (purely due to laziness) i couldn't find any info. Hence now incase someone else will have a similar issue the measurements of the 2000 6n2 1l polo spigots are, front hub -13.3mm +/- 0.05mm   and rear- 16.9mm +/-.05mm . Not sure if this is the same for all 6n2's so do recommend measuring your own if you can.
  • Views 1k
