Polo Mk1-2f Coilover Front Struts - £120
Found these hiding in the shed from back when I had a mk2 coupe. They are OE struts modified by a company called PPS. Will fit mk1-3 Polo. Only ever test fitted, new wheel bearings, powder coat is good. Basically you need some -80mm shocks and a set of 2.25" Coilover springs.
Included are some top mounts and 2x 10" 180lb springs, from memory these are a bit long/high. Pick a spring length and damper to suit your purpose.
Collection only from LE9
£120 takes them.
  • Views 403
