Breadvan van with GT conversion
Make: vw polo
Model: breadvan/hatch back CL
Year/Reg: j (1991)
Mileage: shell 121,565 engin unsure i wont lie or make up a number
MOT:  10/01/2017
Tax: think it was £140 last year
For sale is my vw polo breadvan van replica with the full GT engin coversion done by myself its just missing the GT gearbox.instead it has the standard 1l 4 speed gear box fitted wich works a treat with longer range gears so can go up hills in 3rd with ease works really well with the GT engin. Its got a home made steel exhaused made by myself so it bin de cated a lamba sesnsor boss welded in and just running a rear back box off a g40 slightley bigger bore you see. But still sounds standerd unless you give it some  wich was my plan. Does have a chip in ecu but unsure of make it came with it. Has a de wedged throttle body and a drilled out air box with standart air filter in. runs spot on and goes really well suprises allot of people as you can imagin looking as the van does haha.
Bad points: as you see runs out of mot on 10/01/2017 just dont have time for another polo as i have 2 others in bits already. This is my dailey you see but have bought a octavia tdi to replace this. Probably needs rear brake flexis and brake pipes. poss front arm bushes and maybe cat back onfor emmissions. and a rear shocker. thermostat housing has a few dripps now and then but its not that old. and does have a fault were just after start up verry rarely but if you turn it off and then go to restart it it just cranks and wont start but if you bump it or fire it up in gear itl fire straight up and be fine for a few months again i have tried few things but not solved just lerned and lived with it haha. would make a gpod project or even just for the engin conversion will be ideal as it can be driven home and you can remove and label everything yourself will have tax and insurance on it ony till 28th december so if you want a road test or to drive it home come quick haha. any other questions please let me now cheers
Pictures:will only let me upload one picture for some reason but can send more by e mail or whats app
Price: £400 ono
Contact details: message me on hear or my mobile is 07910312149 if i dont answer im working text me and will ring back when i can
  • Views 518
