Polo 6N2 ignition problem
The timing isn't adjustable as in other earlier cars, it relies on the camshaft timing being correctly set, then the timing is taken from the camshaft position sensor and the ECU adjusts it based on the info from the various other sensors against it's stored ignition maps
The Airbag ECU will only talk via CANbus readers
  • Replies 36
  • Views 6.8k
  • Will try that.. Just looking right now how to get better access to the relaybox..   Googled  "Access to relays on Polo 6N2" and the answer turned up with "With great difficulty"
OK.. Could be a good idea to check the Airbag with VCDS then...
Not now your getting fuel supply, you've got the 3 things required, spark, fuel & air, but if they don't arrive at the correct time it just will not run, so now you have fuel & good spark, I'd be checking the camshaft physical timing
How do you check it properly? Camshaft sensor is new btw...
Here's the full info on replacing the belt and how to make sure it's timed correctly 6N2 AHW Cambelt info.doc
The immobiliser gives a few seconds of running and the makes the car die.........
Any chance???
As afr as I know, the Immo cuts the spark, and I get spark..
Thanks, I'll have a look
An immob fault would automatically flag up a fault code "Start blocked by Immob"
On 2/21/2017 at 17:09, Eslund said:
Combustion requires 3 things.. Spark, Fuel and Air..
Spark is there
Really running out of ideas...?
Hi
Dont forget that you are not seeing the spark inside the cylinder, you are assuming that there is a spark inside. Wet plugs do not spark because the gap is covered by the petrol. Try removing the plugs, cleaning and drying them, and dare I suggest it, increasing the gap a little.
Problem solved in the end..
It was the cathalytic converter that was totally clogged.. Coudnt even blow air trough it.. :)
A car needs more than spark, gas, and air... They need to be able to breathe as well :P
It's sometimes the simple things that can catch you out.
Well done for sorting it and reporting back
