Throttle plate stays closed will not idle
26 minutes ago, nige8021 said:
If you can't get the adaption to run, sometimes you can get the ECU to learn the throttle positions by going for a 30 min drive and with varying loads on the throttle including a few, flat to the floor with the pedal
i'm willing to try anything but i can't even get the car to start without my foot on the accelerator a bit, and as soon as i take my foot off the engine dies because the plate idle position just isn't allowing enough air in. I doubt i could really take it for a drive unless the ecu corrected this issue quickly.  i could probably achieve the same result by putting the front of the car up on axle stands and just taking it through the gears though right?
  • Replies 26
  • Views 8.5k
You really need to drive it to put a load on the engine so the ECU can re-learn the trottle positions to the MAP sensor inputs
