Mint green mk2f afh build
Polo 1992
I brought this polo last year with the aim of shoving a afh in it so I got underway . Stripped everything off brake pipes ,axel ,fuel tank the lot . Every thing was sanded ,cleaned ,painted then put on or replaced with new parts .
Next step was  trying to find a set of wheels and came across a very rare set of image 3 peice splits 7 j fronts 8 j rears got the center's powdercoated and repolished the lips
At the moment I'm at the stage of trying to get it running properly as she only runs on 3 cylinders but one day she will run properly
Everything on the car has been done by me polishing ,painting, rebuild and sourcing all parts I didn't want to go down the rich boy route of sending everything off and getting it back when it's perfect .
Thanks for looking will update as I go but close to finishing now
  • Views 1.5k
Finished lips after meany hours of polishing
Edited by Brad Parr
New disk and pads, arms , steering arms , coilovers , wheel bolts ,and brake pipes
New disk and pads, lower arms , steering arms , coilovers , wheel bolts ,and brake pipes .
Edited by Brad Parr
