Does anyone know how to get rid of dampness in a car? My Polo has been sat since October and the steering wheel has slight signs of mould but there isn't any signs of dampness anywhere else, I know I could probably put a dehumidifier in it but is there anything else I can do? Thanks :smile:
  • Views 1k
  • dvderlm
    dvderlm
    in approximate cost order weld and seal any battery tray rust hole mains condensing dehumidifier mains fan heater peltier element  dehumidifier hair dryer repl
  • Could get a cat litter in a box/tray? Also seen people fill a sock with litter and leave a few around the interior. But for me, and I tried them options and it was still bad, I'd probably strip out th
  • katemelita
    katemelita
    I'll probably go with the easy option first and if it doesn't I will have to strip it, it doesn't look too bad but it's still a worry! Thanks
Could get a cat litter in a box/tray? Also seen people fill a sock with litter and leave a few around the interior. But for me, and I tried them options and it was still bad, I'd probably strip out the seats and carpet and do a proper clean up.
I'll probably go with the easy option first and if it doesn't I will have to strip it, it doesn't look too bad but it's still a worry! Thanks:smile:
  • weld and seal any battery tray rust hole
  • mains condensing dehumidifier
  • mains fan heater
  • peltier element  dehumidifier
  • hair dryer
  • replace door interior membrane seals with large plastic bags
  • moisture trap crystals above  a large flat container so does not spill round corners
  • cat litter
  • drive it with heater on and windows open
  • park on a slope - facing up hill - soak up moisture with sponges and newspaper at lowest point of carpet at back seat wells
  • clean battery tray firewall drain holes
Thank you for those tips :smile:
