Advice about buying a mk2
I'm  looking at getting a mk2 polo. Looking to spend around £1000 so it'll probably be a breadvan as I've seen a few of them on Ebay for cheap. Is there anything I should look out for, common problems, rust areas etc? Thanks
  • Replies 12
  • Views 1.7k
  • As long as it's not bent or rusty, anything else is fairly easy to fix.   The main issue tends to be the previous owners and their repairs and improvements.
  • steveo3002
    steveo3002
    common for idiots to try and fit random ebay wheels by hammering the rear arches , expensive to put right   if you do decide it needs new wheels pick carefully and choose something that fits
  • kiran_182
    kiran_182
    Best advice youll get, be the first in club polo history to take it if you buy a breadvan
check it starts from cold and idles properly..try it again once warm to check it hot starts
rust almost anywhere at that age , most common is battery tray , arches , sills and rear inner arches , check it hasnt been recently undersealed to hide problems
head gasket can leak oil in the corner above the alternator ..lots of them do this and it isnt a huge problem until its dripping on the floor
plenty more can go wrong but its mostly cheap and easy to fix ...rust is the biggest issue
Alright, thanks. I'm really going to check thoroughly for rust, I made the mistake of not looking properly with my Mk2 Golf.
also look up the mot history online see if theres any mention of rust on the old mots
That's a good idea
Idealy go for a mk2f so you get the efi instead of carb. You should be able to get a gt for 1000
If it it's MPI - but you could always fit bike carbs.
If you wanted to go for a mk2f I'd go for something like a CL non-susroof model they are usually less messed with and cheeper, then you can put any engine in you want, 1.3 on bike carbs 1.4 16v, 1.6 16v
glass sunroof is a downside and often leak , hard to repair or buy parts for
Dont i know, had mine 10 years and its still not done.
I did see one thread ( red saloon or coup resto?) That boiled the old seal and clamped it in place and used sealer underneath as it should and it worked though the whole frame had to come out the car to pull it off
