9n3 Polo FSI coolant temperature sensor location
Decided to have a crack at replacing the sensor as it seems like a 2 min job, however being a complete noob, my brain was frazzled after opening the engine cover. Is the green thing in the photo the sensor? Any help would be appreciated, cheers.
  • Views 10k
  • First Welcome to the forum.   That "Green" thing is the oil pressure switch, the coolant temp sensor will be on the thermostat housing, if you follow those thick rubber pipes back you will f
That "Green" thing is the oil pressure switch, the coolant temp sensor will be on the thermostat housing, if you follow those thick rubber pipes back you will find the thermostat housing and it's #8 on this diagram https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/2005-461/1/121-121075/#8
Thanks for the welcome and reply! Will have a look tomorrow morning, hopefully better luck next time.
