Help removing refitting under glovebox shelf 2f
Hello all.
The shelf under my glovebox was removed and hasn't been refitted correctly. It's missing at least 3 screws and it appears to be held up by luck.
What is the best way to remove and re-fit?
Is it:
1. Remove gear stick gaitor.
2. Remove centre console (how many screws?). Does it just slide back?
3. Undo 5 screws holding up shelf?
4. Remove shelf - how do i do this without breaking the plastic peg at the back?
When refitting:
How do you get the shelf plastic peg back in the hole?
Does the centre console just slide back into place?
If someone could help me that would be ace.
  • Views 581
