6N2 front top mounts to a 6N
Hello guys!
I have a 1998 6N, with a 1.6 16v engine swap, and I swapped the springs from a 6n2 last year, but the 6N2 GTI spring sat on the 6n mount, so it sits higher on the front, than it should. Can I use 6N2 top mounts without a problem on my 6N? Is it the same size, or will it cause problems in a 6N chassis? What's the difference between the top mounts? I know the top of the 6N spring is wider than the 6N2, that's why it's not a perfect fit...
  • Views 654
