Gt alternator
The alternator is not charging the battery in my coupe S with a GT engine. When I bought the engine, the seller gave me a brand new alternator (9AR2896G). The mount will need drilled out or the mount itself slaved to suit the top bolt diameter. That's not a problem but the new alternator has a connection which should have a 3 pin plug on one side and a separate spade connector (B+) on the other. Any help with this would be much appreciated. This car is staring to do my head in!
  • Views 697
Here's the electrical side of the new alternator. The one in the car just now only has 2 ring terminals🤔
do you really need to make this work ?  proper ones are easily avail or possibly worth trying a brush pack on the original one
I have just got the car back on Monday from the garage that sourced and fitted a new gearbox, fixed a oil and coolant leak. I can't justify spending another £100 for a new one atm. This was lying in my lock up🤷‍♂️. I fitted it this afternoon, and it seems like it's working perfectly. I swapped the pulley over from the old one, so the original belt fits as standard and drilled out the top mount to match the engine mount. I will try and remember to update this post in a month or so. Hopefully no more dead battery!
