MK2 Control arm is stuck on Anti roll bar
is it bolted on at the front?
  • Replies 26
  • Views 2.9k
  • No I went with your method, so bolting on at the front as the last step. Using a racthet strap to tension the arb worked really well! And then with a long bar to lever the mounts into place at the fro
  • its not too bad if theres movement , lash some penetrating oil on it and give it a good whack ,, some of the bushes will rust onto the bolt so bad theyre almost permanent ...good reason to apply  a da
  • Aha. I believe I have a pre August '84 as well. Engine code GL. After some digging on the internet I found out that the ends should face up when you lay the arb on the ground, so it was never on upsid
No I went with your method, so bolting on at the front as the last step. Using a racthet strap to tension the arb worked really well! And then with a long bar to lever the mounts into place at the front. Can't wait to hit the road again!
Edited by bastibum
