6n2 GTI Engine Timing
Hi there,
Looking for some help when it comes to timing a GTI engine. As it stands I have GTi engine which I have replace the timing belt on. Now I'm not 100% confident that the engine timing is correct after reading from other source you need specific tools. So instead of potentially damaging the engine I want to start from scratch as if I don't know what position the cams or crank is in. What I want to know is what positions the cams and crank should be in and what tools if any are required to get the timing right.
Apologies if this topic already exists but I couldn't find it.
Thank you in advance.
  • Views 469
