Hi Pete
Banbury.
Cheers,
Dan
  • Replies 149
  • Views 37.3k
  • Having paid £159.00 to an 'Automotive Electrical Specialist' garage who totally failed to rectify the fault, I searched the internet and found Pete. As Abingdon is only 18 miles from me I drove over t
  • If anyone is being put off the idea of using this service due to the 'downtime' or inconvenience of having to visit the car twice, once to remove the module, once a few days later to refit the repaire
  • Hey guys just wanted to post a testimony here regarding Pete1's work.   So i used his repair service after spending a lot of time on this common electric window issue. Long story short i ref
Will message you in a sec.
Hi all,
Update on my problems, Having spoken with Pete who was more than happy to refurb my window motor, I was able to borrow a known working window module to test out my original before posting it off..i still have exactly the same symptoms…so i will be looking again at wiring faults.
The 3 fuses that Pete advised me to check are all intact.
I also had a major problem with the door lock module after buying another to fit, it failed in the half latched closed position so I couldn’t get the door open again from in our out, 4 hours of frustration later I have opened the door again thankfully only damaging the lock unit.
i will be looking at wiring to the door lock module first as I still can’t lock door from drivers side after replacing lock module.
As an aside my polo is early 2008 and has seemingly less going on in the window motor as only has one connector to plug in.
Is the ecu part still in it or has it moved elsewhere on the car ?
ECU bit is still in there, just repackaged into a more compact form.
Great stuff thanks Pete, some progress just now think I have found my problem!
As well as the corrosion at least 2 of the male side pins are missing..one of them is the lilac/white which I think you said was passenger window ? will need to source new pins to crimp on !
Yes, definitely got wet for some time that.  I can probably find you a part number for the pins, with a bit of head scratching and ploughing through ETKA info. May need new female inserts in the corresponding door loom plug too.
Ah yes please I have waded through pics of terminals and connectors online and it’s a minefield! They look to be about 0.5mm.
the 20 odd pin connector block they go in is 6Q0 972 737
Male pins are 000979012E, I think, like these
Female, door loom mating part is 000979009E I think. Seem to be far more widely available from UK sources on ebay etc than the male ones.
Edited by Pete1
duff link removed
I think the part number for the rubber boot including the crucial-but-very-breakable white retaining bit at A-pillar end is on page 2 of this thread.
Muuuuch easier to leave white bit in rubber and click whole lot into place together, rather than trying to fit rubber onto that white bit in-situ.
This ebay seller has the female inserts pre-crimped onto repair wires, may be worth asking if they do the corresponding male ones too, or can confirm the part number is as I mentioned above: https://www.ebay.co.uk/itm/315121321097
Thats fantastic thank you, the male pins on amazon wouldn't be here until 11th April, I have ordered some on amazon for a bmw connector repair as a gamble to see if they fit, but they look like the 0.5mm pins.
I will message the eBay seller good tip !
Quick update...I ordered some male pins from amazon meant for bmw but they are mqs fittings by tyco and are very similar with the 0.5mm pin...they don't stay in quite as well as genuine pins but I was able to fit them to test whether everything would work again if I replaced the pins and cleaned up the others....they did ! all working !!!
Pete, I have ordered the correct pins from Latvia using that link with part number 000979012E you supplied, the eBay link you suggested to contact don't supply the pins on their own only in repair wire form @ £10 a go so have ordered the pins and accepting the wait !
Cheers for your help so far !!
Just thought I would offer some feedback following the support that Pete offered me with our faulty drivers window/central locking unit. A replacement was sent out to me which I fitted accordingly, boxed up my old unit in the packaging and returned to Pete, the replacement unit works superbly and I cannot thank Pete enough for his support and knowledge. I highly recommend Pete in resolving this issue. Thanks again Pete!
Hello Pete
New member here. Found this thread whilst continually searching for info on how to fix my window issue. Loads of great info in this thread that has prompted me to message you.
Not a Polo owner, but a VW T5 2009 owner.
My issue is my drivers side window & central locking (from door switch only, not from key fob). After having my door card off numerous times over 2yrs (as well as under steering wheel panels) & many hours of trouble shooting door wire loom etc, I believe my drivers door motor (or at least the PCB within) may be the suspect.
If you still do your repair/exchange of units, could you possibly email me to discuss further.
My motor is an 6Q1959801F (VW750D2DRS)
Many thanks
Phil
Hello Phil, thanks for getting in touch.
I will message you shortly with contact info.
I have seen a few of this 'next generation' motor module now, so should be able to sort it for you. 🙂
Here is another recommendation for Pete's services.
I'm not a Polo owner but have a VW Transporter T5 2009.
My driver's side window & central locking switches hadn't really functioned since Dec 2020. Maybe 2 sporadic periods of a few weeks where they did.
I chanced across Pete's post on this thread whilst searching the net (endlessly it seems for T5 issues) for insights on what the culprit could be. Countless times has my door card been off, under dash trim removed, switches checked, double checked, triple, motor removed & inspected, wire loom unravelled, wires inspected, multi meter out again & again, head frustratingly scratched, & foul language spewed from lips.
Nearly bought a replacement door loom. Then nearly bought a replacement motor off Ebay.
I messaged Pete just this Sat evening, & over this May bank holiday wknd, with his kind assistance via WhatsApp, between us we cracked the problem, & I now have fully functioning windows for first time.
I will say that Pete's services would be a great addition to the VW T4/T5 forum, as I can assure you, they'll be many a T5 owner that are in the same boat with these window motor issues.
Many thanks again Pete
Phil
Hi how do I use this service please I have a sk258d2drs
6y1959801 many thanks
As you discovered Garry, a Private Message is one way to get in touch. There's also an email address at the end of the first post on page 1 of this thread. 🙂
  • 8 months later...
Hi Pete, I would like to use your window motor repair service, please could you contact me at your earliest convenience.
Thank you,
Shaun
HI PETE,
I NEED YOUR SERVICE, PLEACE LET ME KNOW HOW CAN I SEND THE MOTOR,
THANK YOU
Hi Guyro. I will reply to your private message tomorrow. Trying to have a rest this weekend.🙂
Good morning Pete
I would like to use your service - I've tried to e-mail you at movingglass@outlook.com. but my e-mail was "undeliverable. Please forward contact details.
Thanks Sam
Hi Sam, I'm not sure why that would have been undeliverable. Any chance you only wrote 1 'g' in the address, instead of 2?
Anyway, I'll send you a private message now, with contact phone/whatsapp info.
Cheeers,
Pete
This service is awesome. Pete is very knowledgeable and extremely helpful. Repairing an old unit is far better than getting one from a breakers yard (which may not work) and much cheaper than getting one from e-bay etc.
I was having problems with the central locking on my wife’s 2 door Polo. Then both windows stopped working completely. Researching the problem I came upon this thread. I checked the fuses and wiring - everything seemed OK. So I suspected the window control unit.
Pete’s service was also extremely efficient. I contacted him on Monday morning with nothing more than the reg. number and VIN. He agreed with my original diagnosis, identified the correct part from the details I’d given and confirmed he had a replacement unit in stock. It was posted same day and I received it Tuesday morning. Fitted it and everything worked – brilliant. I returned my old unit Tuesday afternoon and by Wednesday lunchtime the rebate was in my account. Throughout the whole process Pete kept me informed by e-mail of what was happening.
This must be the most efficient service I’ve ever come across and I highly recommend it.
Sam Davies
