Are you still doing the repair service?
My daughter's 06 polo front windows have stopped working after a short time of intermittently working
Code 6Y1959801
Thanks
  • Replies 149
  • Views 37.2k
  • Having paid £159.00 to an 'Automotive Electrical Specialist' garage who totally failed to rectify the fault, I searched the internet and found Pete. As Abingdon is only 18 miles from me I drove over t
  • If anyone is being put off the idea of using this service due to the 'downtime' or inconvenience of having to visit the car twice, once to remove the module, once a few days later to refit the repaire
  • Hey guys just wanted to post a testimony here regarding Pete1's work.   So i used his repair service after spending a lot of time on this common electric window issue. Long story short i ref
Hello @Onefut, yes, still repairing. I will message you now with contact details etc.
Just got the refurbed motor today, worked a treat windows now work and central locking works again.
Awesome
Fast efficient and painless service, with good advice as well
Hi Pete,
Been advised that the windows and central locking in my daughters 05 Polo can be fixed with a replaced/refurbed 'drivers door motor module' part number 6Y1959801
If you're still offering the service can you message me contact details.
Much appreciated.
Message sent to you, thanks for the enquiry. 🙂
Hi, I have problems with windows and central locking not working from drivers door. I have removed the motor 6Y1959801 also with Temic numbers 440775FX 401350A8. Can you help with testing/fixing the module.
Many thanks
@Vellan, yes I'll be happy to help you with that. I'll message you with more info.
Many thanks Pete. I posted a request for help on Weds. Pete PM'd me shortly after. Motor was in the post to him the same day. Fixed by him the following day and returned to me on Friday morning. A remarkably short turn around. Motor has been re-fitted to car and windows and central locking are all functional. Good communication and was kept up to date throughout. Very pleased and can recommend the service that has been provided.
Fitted this week, worked a treat thank you Pete such an amazing service, old one in the post.
Hi @Pete1
are you still doing this service?
I have a 9N3 with no working front electric windows
Passenger side switch works the passenger window very occasionally
The window motor part no. 6Q1.959.801F
Thanks
Josh
Hi Josh, yes, still repairing.
I can also offer an exchange unit of that number as a quicker solution. Will message you now with contact number.
Hi all, hi @Pete1!
I have a Polo IV from 2007 and the two front windows don't open anymore. The issue first appeared during the 2023-2024 winter season. Then, during the 2024 summer, it started working again, but not everyday. We changed the fuse but it had no impact. During the 2024-2025 winter, the issue was there again. We then changed the switch and it had no impact, And now, summer is here… which means the car is functional but not really usable.
As it's always been affecting both front windows, and as it had been reacting to heat for a time, am I right saying I'm in charted territory here?
If so, I'd like to know if you're an option for me, @Pete1, because I live in France.
Hi Pete.
Are you still repairing/replacing the window modules please.
If so could you give the info needed.
Cheers
8413bob
Morning Pete,
If you coudl reach out/share contact details - I'd like to take you up on your service too please
Thanks
Adam
Hi @8413bob, thanks for your email which I will reply to shortly; and @Springbokboi, please feel free to email me at the following address:
movingglass@outlook.com
Hi Pete
Done :)
On 07/06/2025 at 15:58, Pic said:
Hi all, hi @Pete1!
I'm back to say that Pete has performed his magic trick again. Front windows are now functioning again. What a relief!
Thank you Pete, and thank you clubpolo. He and this space are typically what make the Internet a formidable tool – experts ready to help, clearly human testimonies backing up what the experts say, searchable and referenced archives. Social media, Chat-GPT and Discord servers were of no help whatsoever!
@Danny Ruane I have just sent you a private message.
  • 3 months later...
Hi Pete, (my 1st post here) I have a 05 polo 1.9tdi gt with window trouble, if I disconnect the battery and leave it for an hour, reconnect the battery, they will occasionally start working ish, sometimes just the passenger side, but never lasts before stopping again, so far I've checked the wires between the door and A pillar, they look fine with no signs of cracking, even fitted a new relay & changed the 100uf cap on the drivers side 6Y1959801 module, still no joy, is it the mc33689adwb ic that dies in them and causes all the trouble? Be way beyond my capabilities if it is, remote central locking seems unaffected, but the using the key in the drivers door just opens/ locks it, the interior light doesnt go out locking with the key, if I lock via the fob then unlock with key, open the door the alarm goes off, till I press the fob to unlock... does it sound like the drivers window module at fault of a wiring break that I've missed? any help would be greatly appreciated,
Thanks, Ben
Not the relay, not the capacitor and not the LIN chip.
Messaging you now.
Hey Paul, my windows have stopped working and an auto electrician has advised I need 6Y1959801, it's for a 06 9N3 1.4. Do you have one for replacement?
Messaging you now @PoloDan1
Hi Pete, have a polo 9n window motor which is not working and requires repair
Messaging you now James.
