6c LED DRL not functioning, OBD eleven scan request
Hi Guys,
I have a 6c with LED headlights. Car came from Japan and coding is a touch different to a European model.
Headlights are auto.
Sidelights are what would also act as the DRL in the headlight.
DRLs are active in the discover media system but selecting/deactivating makes no difference.
Hand brake on or off and light switch in any position also no difference.
I've compared by current scan with the VLB22 and VRB36 settings from rosstech reference scan thread number 13921.
As it is very difficult to compare VCDS and OBDEleven scans directly I am after a full (ideally) or central electric scan using OBDeleven from a 6C polo with LED headlights and DRL working, SEL or GTI would be great.
Attached is my central electric scan.
Would appreciate any help or guidance on how to interpret the many options available on each light and how they interact. i.e. what is DimmingAB, light_function etc.
As I understand
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,70 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,30 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,30 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,00 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,00 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lights ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not active ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light left ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Nebellicht links ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,70 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,30 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,30 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,00 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,00 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lights ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Parking light ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parking light right ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Nebellicht rechts ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LED Tagfahrlichtmodul Signal ,16
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
Central Electrics Coding Adaptations 6C.txt
  • Views 910
