Battery drain problem 9n 1.2E
It looks like 2 large fans to me, the picture isn’t too clear 44BF3D61-728C-4064-8A89-C4BB1AF94CDB.thumb.jpeg.8905481f42fba3372f48039db350637d.jpeg
  • Replies 29
  • Views 3.7k
  • Mark Bennett
    Mark Bennett
    Remember this well Pete,Remember contacting several breakers all of them who had the same unit had the same fault,only plus was as soon as repaired unit fitted,no more flat batteries
  • Have a read of this https://www.clubpolo.co.uk/topic/335902-testing-your-alternator/ just to eliminate leaky diodes in the alternator
  • Clive Chapman
    Clive Chapman
    That’s right, I have to remove the nut and wire plus the 5 amp removable fuse to get the leakage to virtually nothing but if I just remove the nut and wire I still get approx 200mA leakage.  If I leav
I see. Does the aircon work at all, do you know?
Many thanks Pete.
That’s interesting, the air con doesn’t work anymore.  I’m not sure if the fans should come on when air con switched on but they didn’t.  Also they didn’t come on after I switched the engine off. I got the engine fairly warm, up to the mid point on the temperature gauge…
I had a feeling it probably didn't work. It could well be that neither fan is currently operational, or perhaps the main fan may only work at full speed (engine has to get a bit hotter for this).  Worth checking out before summertime.
If aircon is working to any degree, it provides a quick and easy way to check fan function; with a warm engine on a warm day, switching it on and demanding some coldness should result in both fans starting up at low speed within a short time. With cold engine, it may take a little longer but same parallel fan action should happen.
Alternative testing can be done via linking pins in the thermoswitch loom connector, but access to that is a bit awkward.
Are all of the strip fuses intact? One of them supplies current to fans when they are at full speed.
I wish you were a little closer so I could help investigate this car's problems in a more hands-on way.
Any progress on the current drain investigation today?
Hi Pete, no progress today. I was at the rugby watching Gloucester beat Bath 64 nil.  So cause for celebration.  Hope you’re not a Bath fan.
Many thanks for the next pointer, I’ll try linking the pins on the thermostat.
