9n3 1.4 80 hp
Hi everyone 👋
Wondering if there is any changes that i can do with the engine to increase the torque/power to my polo 9n3  1.4 80hp
As far as i know is possible to change manifold, throttle body, injectors and will help to gain some power
There is also a 1.4 100hp, Can be done the change to my engine to get these power?
Any info is a helpful.
  • Views 790
Thanks for reply,
I want to see what is possible to do with this engine,
If is expensive then is better to sell it and to buy already a more powerful one,
I have checked everywhere and there is not much to do,
As you said in and out air,
My throttle body has inside 52mm and 62 outside,
Do you know bigger thorottle body that can be fitted to this engine?
