Oil Pressure Gauge AFT
Hello!
I'm back here again, I have a Golf with the 1.6 AFT engine and i was wondering the correct procedure to installing a oil pressure gauge, I've tried doing some research and i ended up at just pure confusion with the different methods people used, i was going to use a VDO twin-pole but I'm not sure if i should replace the OEM sensor, which i think would be a bad idea.
have any of you done this?
  • Views 185
