VW polo 9n lighting wiring diagram
I'm going to replace the hot air radiator and with that I want to take advantage of the fact that I'm going to remove the panel and run the wires for some options that my car doesn't have, I want to run the wires for the headlight height adjustment and also the fog lights.
I saw the height adjustment wires that come from fuse 6 and go to the adjustment connector and from there a wire comes out to pin 1 of connector D that goes to the engine compartment, but the fog lights, I still don't know how to do it. the call, can anyone help me?
I saw in a video that it comes out of the light switch connector, goes to the fuse holder, goes from the fuse to pin 1 of connector G, is that right?
Is the fog light connection without using a relay and directly via the light switch? How do I make it appear on the dashboard that the fog light is on?
I found the installation of the fog lights in this topic here:
  • Views 1.2k
