Calibrate GT Throttle position sensor
This is for owners of a mk2f GT.
When you replace the throttle position sensor, it needs to be calibrated, or your car may idle funny.  This may need to be performed if you've had a flat battery.
The procedure is:
1.  Start engine,  let it warm up to normal temperature
2. With the car idling, unplug the blue temp sensor for 5 seconds
3. Plug the blue temp sensor back in.
4.  Clear the fault code for the unplugged blue temp sensor.
That's it.  Hope that helps someone
Mods - could you move this to FAQ?
  • Views 392
