Vw polo 6n2 1.4 16v
For sale vw polo 6n2 2001 1.4 16v
Mileage: 77,824
MOT: 12/8/24
Not taxed currently sorn
Good points: low milage very clean and tidy car inside and out literally no rust at all the body is even tidier  underneath
3 months ago had New battery alternator and fan belt
1 year ago had New windscreen front brake disks and pads front suspension arms and anti roll bar links front spring and wheel bearing  brake light switch
 2 years ago New rear brake disk and pads and rear brake pipes/flexis
3 years ago had the usual clutch pedal/box repair done by myself removed the complete unit re welded and added extra brackets for strength
Bad points: usual roof lacquer/paint faded/worn off
Verry intermitant air bag/dash clocks fault will only happen once every few month over winter when really cold
fairly intermitant start up issue usually starts first flick of key no worrys normally but randomly every now and then does allot of cranking seems to get confused but eventually will fire just brings up a fault code relating to engine speed sensor fault after fault has occured
Head lining starting to sag in places
exhaust is blowing needs a centre and rear section
Price: £350
Also can't seem to post pictures up saying there too large so send us a message and i will sort out getting some pictures sent over and any other questions just let us know
Edited by boyzey
  • Views 469
