Polo C mk2 Formel E - no fuel comes through the carb
Pierburg is complex.
The pulldown unit opens the closed choke flap a smidge when engine fires using vacuum akso, then electric and water heated bimetallic strip in autochoke gradually moves choke flap to fully vertical as coolant heats up.
I think the electric just overcomes inertia of flap when really cold, but that is a guess.
There's a part channel heater fuel passage to improve fuel atomization always on.
Theres an electric idle cutoff valve as discussed.
There's vac operated secondary barrel.
There's an enrichment tube.
There's a pump jet.
  • Replies 25
  • Views 1.4k
  • An update - half a can of carb cleaner and the donkey lives!! It's amazing watching the grime wash away into the air intakes... Now it will need some driving to warm the engine through.   Th
  • Many thanks for the advice! I am desperate to try anything that does not require dismantling the carb, although I already bought the set of gaskets. Thanks for the tip with the idle, this sounds very
  • And, thanks for the schematic, this is most helpful!
