Dropped Item in boot
Hi,
I have dropped an apple air tag down a small hole in this part of the boot (circled in picture below). I was not aware there was a hole there and I don’t know where it leads. Can anyone tell me where the hole leads to? Also, will my car be safe to drive to garage to retrieve the item?
Or if anyone has any tips on how to get it out that would be greatly appreciated.
(Image from internet, not my car)
  • Views 626
  • It's probably just sat between the plastic and the carpet, so yeah, no safety risk at all.    I cant think how that plastic bit is attached, a garage would probably take it off and use a mag
I cant think how that plastic bit is attached, a garage would probably take it off and use a magnet on a stick, then charge you accordingly- you could just leave it in there, it's cheaper than buying a tracker 😁
Thank you! Glad it won’t have got in anywhere bad.
