Coolant sensor problem
Hi guys! I have a problem with coolant temperature reading od ECU. When the coolant is around 10 degrees multimeter should read 3.2V but it reads 1.2V. This is the value that should be when the coolant is 80 degrees, so the ecu make wrong mixture of fuel and air and the car sometimes stalling. Anyone have this kind of issues and how can I fix it?
  • Views 309
