Polo Part No. Request Post
I'm after the part number for the radiator for my mk2 g40.
can some1 help me out please it would be very appreciated
luke
  • Replies 167
  • Views 46.1k
Hi luke,
there are two rads, both are 525mm wide,
321 121 253 H >>.. - D - 200 000
321 121 253 BM .. - E - 000 001 >>
Matt
Hi,
I'm after the following part numbers:
G40 Rocker Cover Gasket
G40 Lower Alternator Bracket & Bolts
G40 Supercharger Bracket
Mk3 Non-G40 Cam Cover Bolts (the shorter ones think they're from an HK engine code!)
Jay
I could do with the part No. for a rev counter for Audi 50/polo 1 early round clocks please. cheers :thumbsup:
Is there anywhere I could get this part No please? :-D
dude, etk is telling me these parts are no longer available. there are part numbers, but not for a rev counter. need to find someone with a much older version.
Hi,
Jay
G40 Rocker Cover Gasket 030 103 483 C
G40 Lower Alternator Bracket 030 903 253 B
Bolts 052 903 285 & 909 083 01
G40 Supercharger Bracket 030 199 181 E (also part of engine mount? is that the one you mean?)
Cheers dude, I'll keep looking.... :-D
Part no. for '94 G40 inline electric fuel pump please.
Thanks in advance,
Richard.
Thanks in advance,
Richard.
867 906 091
Hi,
I'm a new member and I'm looking for the part no. for the rectangular blank that fits in between the two front electric window switches on a Mk4 Polo. I've got an unsightly gap at the mo :-( .
Also could someone confirm if 6K0 805 903E is the part no. for a Seat Ibiza Splitter that fits a Mk4 Polo.
And finally can anyone tell me what VAG vehicle this swich panel is from and what the part no. is? (I think it's off a Seat Ibiza but not sure).
hi,
looking for the part number for ...
the water pipe to water pump housing gasket - screw fitting type (not the push in one).
Need the part number for one of those early mk3 passat / golf / late mk2 golf (??) air feeds
used to make a home made induction kit, SITS ON TOP OF THE CARB / THROTTLE
Not to be mistaken with flatter parts used on later models.
apologies for the ambiguity.
is any one able to help with the part no for the center caps for the bbs ra rims with bbs on them
Can anyone tell me what the paint code for the silver 6n is?
Thankyou
part no. for G40 steering tie rod please, the passenger one which adjusts the tracking
thanks mate :-)
anyone help please with part numbers for chrome bumper end caps? (x4)
hi,
Not totally sure on this one but ETOS gives one part number for RHD NZ and 3F engines: N905 197 01 'round seal' (£ 0.75 Ex VAT).
Mine only has the front ones: 861 807 123 (protective end, left front) and 861 807 124 (protective end, right front)
my seats tip about in the rails, so can you stick up the parts and numbers i'll need to sort this out.
(basically anything on or in the rails, and on the seat legs)
cheers.
JB
can anyone tell me the part number for standard g40 clutch?
which bit of the clutch?
clutch plate, clutch pressure plate?
dont worry got it now. thanks anyway
Edited by vwg40ste
need the part number for VWII calipers (found on 8v MK2 gti's and 1.6 MK2 golfs)
cheers.
JB
