Polo Part No. Request Post
what is the part number for a 91 Mk3 Gt Coupe alternator please?
  • Replies 167
  • Views 45.9k
part number for the boot screws on a mark four please :D
....the screws that actually attach the boot lid to the car
1997 VW POLO 1.4 CL 8V
I'm looking for the part number for the CV joint on the right side of the steering rack
and a part number for the the arm on the passenger side front wheel. that's the one at the bottom of the strut
its a bit rusty :(
whats the ampage and maker bosch or valeo? are there any original part numbers on it
output driveshaft for g40. the shorter gearbox side thanks
6n headlight switch with front foglight
this:
TIA
6N2 941 531 J (i think)
hi there
does anybody have the code for 6n 16v AFH metal impeller water pump???
also is there anywhere else other than expencive VW where i can get the water pump. i tried GSF but they only had the plastic impeller type.
thanks
036 121 005 MX Water Pump With Adhesive Gasket For AFH Code
nice 1 thanks
Could someone find me the part numbers for the inline fuel pump and the bit it mounts to on a 91 mk3 gt please.
thanks in advance
867906091
fuel pump
/ NZ,3F,PY
867201515
clips / for fuel pump
867201503A
carrier panel
part no. for the clips that holds the dizzy cap onto the distributor on a 6n please!
867906091
fuel pump
/ NZ,3F,PY
867201515
867201503A
carrier panel
thanks Giorgio, much appreciated.
Resolved, no part number as it comes with the distributor and not sold seperatley. £85!!!!
number for a mk5 (6n2) gti splitter
and
euro LHD 16v tail light
and
gti splitter : 6N0 805 903 E B41
and
6N0945095B
tail light with rear fog light / partially dimmed:
left lhd black /
Edited by AMD_Man
Got myself a polo Gt coupe and needing the fuel pump relay part no?
Part number for Retro Fit aero wipers > 2001 Polo 16V. Thanks
part number for mrk5 rear red lights with bolb holders.front orange mrk4 polo indicators that will fit inpro crystal headlights.
(dont think there is any difference between oem headlights)
Could someone do the honours of a part number for the METAL exhaust manifold gasket for a late 6N!
Jay
Part number for a heated seat swtiches for a mark 4,or if they are the same on others like a passat.
Could i have the part number for the roof strips (the thin black ones that are above the doors) for a polo G40?
I ordered 867 853 705B and 867 853 706B but these are for the squareback and no one can find the numbers for the coupe!
Hi Guys
Now posted much on this forum - but try:
http://www.vagcat.com
signup - and you got an online vag etk!
Q
Part no for brake discs and pads for a 1998 6N polo 1.4cl 8v.
Asap if you would be so kind.
Ted.
