Put my polo SP back on the road.
It's now historic vehicle.
No road tax.
No MOT tests.
Fitted a radio again that drained the battery and had front panel would not leave demo mode.
Offside screen washer jet worked then blocked.
I replaced a broken front spring, while changing the front shock absorbers because the pot holed roads are terrible nowadays.
First the choke cable detached from the enrichment mechanism, requiring a strategic screwdriver for cold starting.
Filled up at Tesco. Had an 8p a litre voucher
but idiot me tapped my payment card before cashier had taken the money off the whopping price of Momentum 99 since I last used the car.
And last but not least the clutch cable (new in 2018 but done way under 10,000 miles) made a "gallang" noise and the clutch pedal dropped 4 inches.
Tightened up at the gearbox release lever in the dark, until could select reverse again with pedal nearly at the floor.
But wow it sounds glorious on the twin carbs.
Dunno why I fit the radio really.
How's everyone else doing?
  • Replies 13
  • Views 209
  • Sweet besides the hickups along your way ha sounds fun non the less. I just unplugged the ignition on my radio and it doesn't drain battery, just have to turn on manually. Twin carb sounds cool, what
  • Good to hear you've got it going again. I'm in a modern daily, and my old VW fix is a Seat Cordoba Vario TDI (mk4 polo estate basically) - Total shed. I'm just changing the broken pedal box that'slef
  • Wiring is too simple.. original radio had an on/off switch and buttons.I bridged standby and main power which was probably a mistake. Now trying unplugging the anti theft front panel. It has a GK eng
Twin carb sounds cool, what engine did you partner this with?
I'm in a modern daily, and my old VW fix is a Seat Cordoba Vario TDI (mk4 polo estate basically) - Total shed. I'm just changing the broken pedal box that'sleft the clutch pedal about an inch from the floor since I got it, 2000 miles ago. But it does 60mpg and runs on anything that looks a bit like diesel.
Edited by Yeti
It has a GK engine.
I'm in a modern daily, and my old VW fix is a Seat Cordoba Vario TDI .... But it does 60mpg and runs on anything that looks a bit like diesel.
Pre Pumpedüse will run on veg oil which is cheaper than diesel even new in a bottle, none of that filtering chip scraps and moisture removal required apparently.
The clutch cable has frayed near the pedal. Driven it for 4 days like that.. not risking another gear change until I can fit a new cable (ordered).
The company i ordered from
were even good enough to check whether I really wanted a shorter left hand drive cable.
And the choke cable... turns out the bolt and 2 odd sized washers I've used for years is wrong.
(one can usually start from cold with accelerator pedal pumps between cranking tries... but that takes several to many attempts, not good idea with drained battery and price of petrol.
Hm, I suppose I could spray EasyStart down the 4 joined vacuum ports straight into the inlet runners.)
There should be a hole across the bolt that you put the choke cable through. Then you tighten down into a threaded hex piece clamping it all securely, no tendency to pull tangentially and loosen.
Don't think I can accurately drill across an M4 bolt by hand.
So, Dellorto part 7062 on the way from Eurocarb.
yeah, the only way to do that is spin a nut all the way on to the bolt, file a flat in one side of the bolt, drill it with a pillar drill and spin the nut off, hoping it does enough to the thread that you can run a die back the other way.
Or buy the right bolt 😁
Also, vegetable oil sounds a bit posh, it's been on 50% used engine oil all last week.
Edited by Yeti
Might try that as the 7062 bolt has not arrived yet and the trains are sadly abysmal.
Waste engine oil must need good pre-filtration.
Rudolf Diesel used peanut oil in 1900 Paris exhibition. Lots of sunflowers and rapeseed grown near me.
new choke cable fitted.
It has a solid core so no strands to fray.
I did have to drill the bolt wider to 2mm hole.
Clutch cable: took about 90mins to remove the old one.
The SP model has a Stabilus 1942DS Stab-o-shoc hydraulic steering damper and the bulge of its cylinder obscures the clutch cable bulkhead hole. Two metal D shaped washers around the cable's old and hardened grommet tend get stuck fast if you just pull.
Maybe I undid the other end of the damper mount 8 years ago - before twin carb trumpets made access awkward.
I fit the DHLAs in August 2016 so I must have done something similar.
Damper bolt won't come off nearside. Can't get a 15mm socket on it for the old rubber.
But at the steering clamp it will come off from underneath.
No need to remove the carb trumpets.
New clutch cable fitted an adjusted for 6mm free play at the release lever.
Tighten the cable nut half a turn every 5000 miles according to Mr. Haynes.
On 28/10/2026 at 18:18, dvderlm said:
Holey bolt and washer ..
Robin's 'Holy ____!' Catchphrase Compilation | 1966 Batman | TikTok
Third week of driving it again daily.
On the plus side:
The starter circuit is working really well.
Pull the new choke cable all the way. Don't touch the gas pedal at all. Turn key. Instant start. After about 10 to 20 seconds it can pull away. Before that it dies. Drive off, push choke to half way after a 100 yards or fully in once the throttle feels responsive. I did use the engine preheater this week. This morning that was great as it was -2°C overnight. And I'm on the skinny 4.5" wheels and winter tyres already, with the huge radiator one third covered. No warm air feed required yet.
Filled up as fuel gauge needle was just entering the coloured reserve band. I seem to have managed an astonishing 419.7 miles on 36.35 liters of Momentum 99, which I reckon is 52.5mpg or 5.4 l/100km.
(I have a 42 liter tank with supposedly 6 to 7 liters reserve left at that reserve point)
I reckon people are driving more slowly, 20mph limit in town, 55ish on A-roads, and I've been trying to do any commuting to/from work at quieter times of day.
On the negative side:
Exhaust bracket is drooping from the chassis at one end so exhaust is dangling but the 2 rubber bands are still attached. I blame the potholes and speed bumps.
I reckon the pump jet stroke needs a slight tweak to increase the shot volume, exiting a roundabout and accelerating out needs a bit more oomph.
New cars' headlights are so dazzling bright.
Petrol is how much?
Still not used the radio.
