Single Wiper Converstion
OK SO I've DONT THIS CONVERSION AND IT WORKS GREAT !
BUT THERE SO MUCH PLAY BECAUSE I've CUT THE OTHER WIPER BIT OFF THE MOTOR MOVES AROUND AN NOCKS ? ITS REALLY ANOYING !
DID THIS DO THAT ON ANYONES HERE WHEN THEY DID IT ?
  • Replies 29
  • Views 17.9k
yep mine does it, think its just because the rubber bushes that the bolt sits in to hold the motor are shit, knocks against the bulk head??? try replacing the rubber bush for something more stirdy, crush tube or thick washers maybe?? and a more beefier nut will go down a treat aswell instead of the shitty phillips head screw that was holding mine down also maybe stick some rubber between the motor and bulkhead to absorb the knocking
I've got a bigger washer and a 10 mm nut to hold it place better and I've put rubber behind it already and tbh it still does it and the motor knocks a bit !
Great guide! I will give this a go when I have chance.
  • 1 year later...
anyone make this on mk4?
