Help
Right its a mk3 polo gt coupe with poloace chip and jetex system standard otherwise bar supension
and before i do anything else engine wise i want to get it running right
I went to check my co at work and its around 0.6% I'm pritty sure this should be around 1.0 to 1.4% according to haynes
I've checked the timing it seemed a little out but seems ok now although at idle with blue temp plugged in it was a little irratic (sp) tho, with it unplugged and at 2k as advised by psd couldnt see mark
I've changed the blue temp sensor (VAG) but I'm going to check it
I'm going to check the throttle potensionmeter
is there any way of checking the afm
does it have to be put to a perticular setting i.e base to be set up
I'm doing it off the front pipe not the exhaust made this mistake doh
anything else i should check
all advise help appreciated
cheers
Ash
  • Views 856
