mk3 dials
one of many things that bug me about the mk3 polo are the dials there so fucking boring!
The clocks are straight out of a VR6 Golf, I bought the Plasma dials from the USA, while fitting them I fitted bulbs behind each clock and Fibre-optic needles from an Audi 80 which makes the needles glow. Most of the wiring is the same, and the G40 plug goes straight into the clocks, I had to add wiring for things like the MFA Stalk, had to use an Electronic Speedo sensor in the gearbox and wire up ( this came of a Mk3 Golf although I need to fit a VR one to make it more accurate). The dash also needed a bit of chopping to fit the clocks in.
this is all the info i have if any one could explain a bit more?
  • Views 899
