positive wire to amp-easy solution MK4
wrote this in reply to another topic-
ok, on my mk 4, i found an easy way- there is a hole (and rubber seal) in the bulk head where the hose of the rear washer system goes, providing that you are not using mega guage wire, this will fit (its tight!) remove glovebox and the hole is behind some fire profing. The wire can then be run down pasenger side under trim.
Some might say that this is dangerous, having a 12v wire run next to a water pipe, but if you observe the direction of the water pipe- it runs down out from the tank, then up over the suspention stut bolt, then back down. which means any leak that may occure from the tank will not come in contact with the bulkhead. If this makes sence. try it and see. this is a very easy way. worked for me, and it keeps every thing on same side as battery!!!
  • Views 767
