EATON G40 PICS
when the eaton sound gets anoying its plan b Incubus cd on nice and load that never gets anoying
  • Replies 38
  • Views 6.8k
The Eaton sounds good...but how long could you put up with that noise for. It would surely get old pretty quickly.
never gets boring EVER!!!
seeing peoples faces as you whistle past sounding like your being pushed by 10,000 screaming fireworks
is sooo true!
i have had someone fall in a bush trying to turn round so quickly to see what the commotion was!
Nearly crashed laughing so much
haha
(and i wasnt ragging it just put boost on- gotta love immediate fulll boost - all 22psi of it!!)
i cant wait to get mine done :D
gna be wicked, LRegG's red eaton was amazing
Thanks garry
Although i've got the turbo beige beast for my boosted thrills, it still doesn't quite compare to the instant throttle response of the eaton
I cant wait its gonna be amazin woowoo role on sunday!!!!!
Edited by Edlin
ok got the kit way THANKS BEN. 1 of many questions radiator gonna have to move it down correct???couple of blocks of stainless should sort that out. next question (dont know the name) the bit that runs vertically down from the bonnet catch is this cutting time??
Edited by Edlin
any one??
It holds the horn doesnt it? That has gone on mine. The horn now sits at the far passaenger side of the engine bay. I'll PM you some pics of the front of mine.
ay up ben its not the bit the horn go's on to but thinking about it that could get in the way 2... heres your car its this bit i didnt no if it was nesersery to cut it out???? any one else had this problem??? frontmountg40.jpg
Edited by Edlin
ummm, its still there on mine, so guess you dont need to cut it out.
JOB DONE WAYHAY. just been for a quick test run as i need tax its mint thanks every one who helpped me out and if any one can point me in the direction of good brakes i can see them on the horizon.
Yoof and Henry are trying to sort something out re: bigger brakes. Click me for bigger brakes Or you need a set of VWII calipers IIRC and you can then run 256mm discs, though you will need 14"'s for that.
And dont go running it lean and melting a piston! Get bigger injectors and chip to match.
id love a set of 4 pots for 256's, I've got 280's on mine atm.
They stop really well, have got them under 14's atm.
They will go under my 13inch wellers but my god they are tight!haha
Yeah deffo agree with not running it lean! thats the last thing you want to happen!
and make sure the belts run perfectly straight! or you will find yourself stripping belts left right and centre (like me!!haha)
the last one lasted 20 mins! (am getting hold of a pulley from the cooper s as it is the same width as the belt and adjust the spacings of the pulleys.
Then all done!!!
yay!
chears for you help guys I'm ot gona run it up until i get the injectors and the rest of the bits a bobs. looks like those brake are taking there time, any faster options what is the VWII you mensioned??
